Simple Fret Press Caul For New Boards Unattached http://www-.luthiersforum.com/forum/viewtopic.php?f=10117&t=38487 |
Author: | Chris Paulick [ Sun Dec 09, 2012 2:14 pm ] |
Post subject: | Simple Fret Press Caul For New Boards Unattached |
Author: | Chris Paulick [ Sun Dec 09, 2012 3:01 pm ] |
Post subject: | Re: Simple Fret Press Caul For New Boards Unattached |
I use my mini mill and there isn't a problem with it. I don't see it being a problem for a drill press. Not really that much pressure to press a fret in my opinion if slotted correctly and with a lead filed in. CA and glue will size the wood if somewhat spongy and the fret will hold better and be more solid. It's good for loose frets and will prevent dead sounding frets. It will also lube the fret slot and make pressing a little easier I guess too. Whether or not you use it is up to you in the end. I made the video because I had to press this compound radius board and didn't have the time to make or cash for a set of cauls. I had given some thought to putting a bearing on the end of a shaft and roll it over the fret as it pressed it. But what the hell, the bolt and poly took about five minutes to make and worked fine. Beats noisy hammering and seems to follow the board radius. I was just thinking out of the box again with this one and it just happened to work out this time and thought I'd share it. ![]() |
Author: | muskr@ [ Mon Dec 17, 2012 1:51 pm ] |
Thanks for posting, I think I might make myself one. Any ideas for using it in a drill press without a sliding vice? |
Author: | Chris Paulick [ Mon Dec 17, 2012 4:41 pm ] |
I think you might try a pecking motion and as you raise up slide the board. Just as you would if you were hammering in frets except you are pressing it in. When you get to the ends you will want to go just past the edge of the board and press the overhang of the fret down slightly to set the ends. Just be careful not to over do it. Sort of like tapping the ends down when hammering in frets. You want to have the tail end of the frets bend down so it sets. You could try and press the ends first and work across the fretand see how that works out. This method isn't the fastest or the best. It's just an alternative to hammering and another way of fretting as I see it. |
Author: | WilbPorter [ Wed Dec 19, 2012 3:13 pm ] |
I like the singer. Interesting idea too, chris. |
